Discussion topic: Broadband keeps disconnecting from sky q box
This message was authored by: Charley14
Several times a day the broadband connection to my q box and mini box is dropping out- it resolves itself after a few minutes but then happens again and again.
It means the tv is barely usable, we keep trying to watch things on iplayer or prime etc and can only watch a few mins before it cuts out.
other devices are connecting to the broadband fine and it says there's no issue in my area.
don't know what to do and getting really frustrating paying so much money for a service we can't use!!!
Re: Broadband keeps disconnecting from sky q box
Hi @Charley14
Try completly resetting your Q box connection.
Avatar for Charley14
just tried this and it worked for about 30 seconds before cutting out again...
unfortunately now all our other devices need to be reset!! 🤦🏻‍♀️
This message was authored by: mabes76
Sky Q Disconnected from broadband 7 times today. Completely ruined a family film moment.
Awful service as per usual.
Not sure what £££££ gets you now.
maybe time for a dodgy fiestick.
