Discussion topic: Sky Q box
This message was authored by GrimReader This message was authored by: GrimReader
Sky Q box
My Sky q box and my tv won't recognise each other. I am on my 3rd box and sky "cant" send an engineer until the 21st Feb next year. Meanwhile, I still have to pay for sky tv. I'm not at all happy! 🤨
Re: Sky Q box
What exactly is your issue @GrimReader ?
ie in what will they not recognise each other?
GrimReader
Re: Sky Q box
Hi, Oldfella! The tv gives me a "no signal" notice, and the sky q box doesn't go past the "you will be up and running..." notice. The sky q box light stays on red. I haven't moved any cables from anywhere, until the  fault first began. I have been through the reset so many times!
Re: Sky Q box
Hi @GrimReader
Have you tried pressing the Standby button (Amber led) on the front of the min box.
If this turns the mini box on
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
GrimReader
Re: Sky Q box
Unfortunately, I don't have a mini box. I only have a main box.  Since the box won't turn on, I can't connect the remote.
This message was authored by Chodley This message was authored by: Chodley
Re: Sky Q box
"The tv gives me a "no signal" notice, and the sky q box doesn't go past the "you will be up and running..." notice."
How are you getting both of these? Is it at different times?
Re: Sky Q box
Sorry @GrimReader .
Its the same procedure with the main Q box.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Re: Sky Q box
He said the button light is red though, not amber, I think?
GrimReader
Re: Sky Q box
Have tried all of that!
Re: Sky Q box
  the "Answer" button doesn't mean "reply" on here.
It means "this post has the right Answer to my problem."
GrimReader
Re: Sky Q box
Hi, Chodley! The button light is red!
Re: Sky Q box
Yeah that's what I said
That says to me the box is knackered and unable to boot properly.
GrimReader
Re: Sky Q box
So, you can probably tell, I'm new. 🫠
GrimReader
Re: Sky Q box
It's the 3rd box in a week. They can't all be broken, surely?
Re: Sky Q box
It happens quite often 😄. Confusing because the actual Reply button is just a swooshy arrow. Unintuitive.
