Discussion topic: Sky Q box
Message posted on ‎27 Nov 2024 06:40 PM
Sky Q box
Message posted on ‎27 Nov 2024 07:24 PM
Re: Sky Q box
@GrimReader wrote:
My Sky q box and my tv won't recognise each other. I am on my 3rd box and sky "cant" send an engineer until the 21st Feb next year. Meanwhile, I still have to pay for sky tv. I'm not at all happy! 🤨
What exactly is your issue @GrimReader ?
ie in what will they not recognise each other?
Message posted on ‎27 Nov 2024 07:32 PM
Re: Sky Q box
Hi, Oldfella! The tv gives me a "no signal" notice, and the sky q box doesn't go past the "you will be up and running..." notice. The sky q box light stays on red. I haven't moved any cables from anywhere, until the fault first began. I have been through the reset so many times!
Message posted on ‎27 Nov 2024 07:35 PM - last edited: ‎27 Nov 2024 07:36 PM
Re: Sky Q box
Hi @GrimReader
Have you tried pressing the Standby button (Amber led) on the front of the min box.
If this turns the mini box on
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on ‎27 Nov 2024 07:39 PM
Re: Sky Q box
Unfortunately, I don't have a mini box. I only have a main box. Since the box won't turn on, I can't connect the remote.
Message posted on ‎27 Nov 2024 07:42 PM
Re: Sky Q box
"The tv gives me a "no signal" notice, and the sky q box doesn't go past the "you will be up and running..." notice."
How are you getting both of these? Is it at different times?
Message posted on ‎27 Nov 2024 07:43 PM
Re: Sky Q box
Sorry @GrimReader .
Its the same procedure with the main Q box.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Re: Sky Q box
He said the button light is red though, not amber, I think?
Message posted on ‎27 Nov 2024 07:44 PM
Re: Sky Q box
Have tried all of that!
Message posted on ‎27 Nov 2024 07:45 PM
Re: Sky Q box
the "Answer" button doesn't mean "reply" on here.
It means "this post has the right Answer to my problem."
Message posted on ‎27 Nov 2024 07:46 PM
Re: Sky Q box
Hi, Chodley! The button light is red!
Message posted on ‎27 Nov 2024 07:46 PM - last edited: ‎27 Nov 2024 07:47 PM
Re: Sky Q box
@GrimReader wrote:Hi, Chodley! The button light is red!
Yeah that's what I said
That says to me the box is knackered and unable to boot properly.
Message posted on ‎27 Nov 2024 07:48 PM
Re: Sky Q box
So, you can probably tell, I'm new. ðŸ«
Message posted on ‎27 Nov 2024 07:49 PM
Re: Sky Q box
It's the 3rd box in a week. They can't all be broken, surely?
Re: Sky Q box
@GrimReader wrote:So, you can probably tell, I'm new. ðŸ«
It happens quite often 😄. Confusing because the actual Reply button is just a swooshy arrow. Unintuitive.
