Discussion topic: Sky Q box
This message was authored by: 1961
Sky Q box
Hi I got a new sky Q box yesterday and can't get it to switch on this morning
Re: Sky Q box
https://www.sky.com/help/articles/sky-q-box-wont-turn-on#:~:text=Restart%20your%20Sky%20Q%20box,back....
Re: Sky Q box
Hi @1961
Did you pair your Q remote to the new Qbox?
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
