5
This discussion topic has been answered Discussion topic: Sky Q box
This message was authored by: Vickibee123
Sky Q box
The apps aren't working and it keeps switching off. Then blue screen comes on saying service unavailable . Press home button. Any advice as to what's wrong with it? Thanks.
Re: Sky Q box
Hi @Vickibee123
Re: Sky Q box
Hi @Vickibee123
This message was authored by: Jmoulding
Re: Sky Q box
Power cycle may do the job too! Check WiFi is connected
DRX890
DRX895
Avatar for Vickibee123
Re: Sky Q box
Thank you. I'll give them both a bash tomorrow. X
This message was authored by: Tanyagulati
Re: Sky Q box
How can I change the wideband to lnb. My sky box says no signal after I've reset it
Re: Sky Q box
@Tanyagulati you would only need to change th LNB type If on a communal dish you need to reset the LNB to SCR in the hidden menu. After changing the LNB type you need to reboot the Q box.
Answered - Go to Answer
