Discussion topic: Sky Q box wont turn on
This message was authored by: Jamie58
Message posted on 12 Feb 2024 07:57 PM
Sky Q box screen is just snowy
Find out more
Message posted on 12 Feb 2024 08:02 PM
Re: Sky Q box wont turn on
@Jamie58 Have you tried rebooting your main Q box ie
If that doen't work make sure that your TV is on the correct HDMI input for the Q box
