Discussion topic: Sky Q box not working properly
This message was authored by: Gerdmc
My sky Q box doesn't appear to be working, keeps dropping and freezing. Have switch off and on at wall several times. Recordings not working. I've had the sky Q box a few years now - feels like I might need a new one. Often seeing the message at top of screen 'there is a technical fault with this channel...
This message was authored by: Doc5907
Re: Sky Q box not working properly
@Gerdmc
Try a Reset Settings in the hidden menu.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Gerdmc
Thank you - I've done that and re-paired the remote but still problems eg won't let me rewind or view recordings and now screen frozen again. Ive switched off and on again
@Gerdmc
In that case, as you suggested, it could be the box is on the way out. Probably time to give Sky a call and get an engineer out who may eventually replace the box.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Gerdmc
Yes that's what I thought. Thanks for your help
