Discussion topic: Sky Q Minibox
Message posted on 15 Jul 2023 01:07 PM
Sky Q Minibox
One of our Sky Q mini boxes has stopped working and a message appears on the tv saying “error MR102".
Please help!
Message posted on 15 Jul 2023 01:08 PM - last edited: 15 Jul 2023 01:09 PM
Re: Sky Q Minibox
Please help!
Hi @Suz+B
Reboot the minis as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
If a connected mini is nearer this can also be used for the WPS.
Message posted on 15 Jul 2023 01:09 PM
Re: Sky Q Minibox
We have tried this and still have the same problem.
Message posted on 15 Jul 2023 01:28 PM
Re: Sky Q Minibox
