Discussion topic: Sky Q box needs to keep being unplugged
Message posted on 28 Oct 2024 07:13 PM
Every day I have to keep unplugging my sky Q box so it will reboot, as it won't turn on after being in standby mode.
Message posted on 28 Oct 2024 07:16 PM
Re: Sky Q box needs to keep being unplugged
Is this very early in the morning (before about 0545)?
Message posted on 28 Oct 2024 07:49 PM
Nope it's all times of the day, after the box has been in standby for a period of time.
Message posted on 28 Oct 2024 08:08 PM
Hi @Craig3256
Message posted on 28 Oct 2024 08:17 PM
Thank you I'll give this a try
Message posted on 21 Apr 2025 08:09 PM - last edited: 21 Apr 2025 08:10 PM
It's doing it on my main box and my minis.. both will not turn on from remote or buttons in front, need to be unplugged and then go through whole start up rubbish everytime
Message posted on 21 Apr 2025 08:13 PM
@StevenC19 have you tried the reset as suggested in @oldfella post 2 above yours
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
