Discussion topic: Sky Apps Crashing
This message was authored by: Woodey86
Sky Apps Crashing
Hi My sky Q box that I have ahd for around 3 years keeps crashing whilst i am usong the apps. It wasn't to bad at first but lately it's become unbearable. Every 5 mins I have to press home and reload the app. I can't get trougha full episode without having to re start it l. Sky can you help?
Re: Sky Apps Crashing
@Woodey86 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
If you have not done so have you tried rebooting your main Q box ie
the other thing to try is
refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
