Discussion topic: Sky Q box issues
Message posted on 26 Dec 2023 08:24 PM
Sky Q box issues
Recently ive started to have problems with my SkyQ box which is a few years old now...
- Recorded Programmes freeze and the box locks up
- Sound drop outs, sometimes every couple of seconds
- TV channels suddenly all show only a black screen. (Signal is absolutely fine)
- Unable to watch films on sky movies, i try to download to watch but nothing happens. Reset the box and Im able to watch the movie.
- A lot of my recordings ~90% are suffering from "Software issue" which affects the playback in the form of stuttering image, or you cant watch past a certain point (if it would playback at all)
I imagine I need a replacement box unless someone knows how to do a system reset instead?
Message posted on 26 Dec 2023 09:10 PM
Re: Sky Q box issues
Hi @WoodyR98
Message posted on 28 Dec 2023 07:08 AM
Hi. I tried the basic reset which didn't work. I've now done the hard disk reset which might have done the trick. Going to need to use it a bit to test it.
Message posted on 28 Dec 2023 11:48 AM
Sound drop outs lots of recent posts on this forum regarding this and I think it's linked to the latest software rollout.
