Discussion topic: Sky q mini box is not working
Message posted on 28 Dec 2023 10:27 AM
One of my sky boxes is not working, main box and the other mini box is fine all with signal.
Message posted on 28 Dec 2023 10:52 AM
Re: Sky q mini box is not working
You may need to give a bit more detail than 'not working'...
Message posted on 28 Dec 2023 11:20 AM
Hi @Sichazj
First try rebooting the main Q box and then when this is completely back up and running reboot the problem mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. You can also use WPS on the other connected mini if it is nearest .
