Discussion topic: Sky Q and ethernet
Message posted on 27 Oct 2024 02:08 PM
Sky Q and ethernet
I would my main sky q box to use it's ethernet connection from my router to seed up streaming services. This seemed to work when i turned off wifi in the hidden settings menu. Connection to netflix all was instantaneous etc.
However, turning off wifi essentially killed my sky q mini boxes, which are connected via wifi. I had assumed they were connected to the main sky q box on it's own discrete network (i guess not).
When i have both ethernet cable connected and wifi enabled, my speed speed seems dictated by the wifi connection,. so i guess it's not using the ethernet connection when wifi is enabled?
Anyway, is there a way to set up so my main box gets the benefit of ethernet speed from the router, and i can still use the mini boxes via wifi (ethernet connection not an option).
Thanks.
Message posted on 27 Oct 2024 02:20 PM - last edited: 27 Oct 2024 02:21 PM
Re: Sky Q and ethernet
Hi @Robbob123 Do you have Sky broadband, if not then simply turn off 2.4GHz only. The Sky Q Mesh uses 5GHz.
Message posted on 27 Oct 2024 02:21 PM
Hi. No it's BT
Message posted on 27 Oct 2024 02:24 PM - last edited: 27 Oct 2024 02:25 PM
Hi @Robbob123 The Sky Q box uses 2.4GHz with BT routers, so turn off 2.4GHz and then it should use 5GHz to connect to your Mini boxes and connect using Ethernet.
Message posted on 27 Oct 2024 02:25 PM
Perfect. Will give that a try. Thanks.
