Discussion topic: Sky Q Remote
Message posted on 22 Jun 2024 06:46 PM
Sky Q Remote
New Sky Q Remote no home bottom
Message posted on 22 Jun 2024 07:02 PM
Re: Sky Q Remote
Hi @Enfield-1
First check that the home button is not stuck or sticking.
Then
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
