3
This discussion topic has been answered Discussion topic: Sky Q Recordings
This message was authored by: phil19651
Sky Q Recordings
Sky Q is cutting the programme end off.
Can I extend recording times of programmes on the Sky Q box?
Thanks Phil
This message was authored by: nigea99 Answer
Re: Sky Q Recordings
Thanks Phil
hi @phil19651
On SKY Q all recordings start end end are governed by the EPG and you cannot extend, unlike SKY HD
If you have problems with specific programmes probably best to email Viewer Relations : viewerR@Sky.uk
Thanks Phil
hi @phil19651
@phil19651
No, not like you could on Sky+. You would need to record the next programme too but to be honest I've had Sky Q for nearly 5 years and that has only happened once or twice.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Avatar for phil19651
Level 4 icon
Thanks for the info.
Phil
Answered - Go to Answer
