28 Mar 2023 01:32 PM - last edited: 28 Mar 2023 02:21 PM by Chloe-W22
Today noticed I could not download anything to my Sky Q box - using virgin broadband. All my other devices in the house are working fine. No issue with my Broadband.
Tried restarting router
restarting Sky Q Box
Doing a network reset on Sky Q
nothing works. It was all working last night - but today seems dead. Have tried everything. Anyone got any ideas on this ? thanks
28 Mar 2023 02:16 PM
Posted by a Sky employeeHey @dino9898,
Are you on VM Broadband by any chance? Virgin Media are investigating an issue with Sky Products connecting to the internet today, the main chain is on the Glass board 🙂
28 Mar 2023 02:18 PM
Hi yes I am with Virgin Broadand using Sky Q box (not glass) thanks will check the other board you shared
28 Mar 2023 02:20 PM
Posted by a Sky employeeNo probs, it's getting looked at as we speak.
PS - I'm going to amend your title slightly so other Sky Q customers can find it if they are experiencing the same 🙂
Cheers Chloe - to clarify this virgin router/hub issue is affecting both SKY Q and Sky Glass customers ?
thank you )
28 Mar 2023 02:23 PM
Posted by a Sky employeeIt is unfortunately, Q, Glass and Stream
28 Mar 2023 02:24 PM
well at least its not local to my equipment so will just wait this out for Virgin & sky to find the fix
thank you for clarifying this )
28 Mar 2023 03:12 PM
All back up and running again for those who aint seen the other thread - and others saying its all working again - happy days )
05 Jun 2023 07:00 PM
Message on TV says it looks like you do not have Internet connection right now
Second box says there is problem with network setup
I have held WPS as suggested no luck
05 Jun 2023 07:08 PM
Hi @Gail+0963
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
19 Jun 2023 07:24 PM
Can I ask what others did for everything to be up and running again? I've had this issue for months and driving me mad. Sky Q box and VM net. Thanks 😊
16 Jul 2023 12:33 PM
I am suffering the same issue. I have turned both Sky Q box and my Virgin router off and on 4 times now, I have reset the network and still says connected but no Internet. All my other devices i.e. phones, tablets etc all work as they should. Any ideas on a fix
04 Sep 2023 05:50 PM
Hi
I have multiple clients calling us to say that there Sky Q has no internet connection. We have attended 2 already and found both had Virgin Broadband. I have now attended another with the same fault and can not get any internet on sky Q and only Sky Q.
All other network connections are fine.
Too much of a coincidence that they all have the same set up with Virgin Broadband.
can this please be checked. I also have the same issue at my own home . Have seen there was an issue a few months ago but apparently resolved.
04 Sep 2023 05:55 PM
@AvcommTV wrote:
Hi
@AvcommTV Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Has virgin sent a firmware update for their routers recently ?
04 Sep 2023 06:01 PM
Hi
yes i know
just thought it may get to sky quicker as trying to get a hold of anyone there or at Virgin Media is a nightmare.
also just in case anyone else is having the same issue. We have had a good few calls today with the same problem and as I said also at my own home with the same set up.
