04 Sep 2023 10:21 PM
Same here I'm in Glasgow and have virgin broadband but it's not connecting to my sky Q box it says connected to router but no internet connection everything else in the house is working phones PlayStations Xbox all working fine with internet
04 Sep 2023 10:28 PM
Hi...I have this issue now and I can't see what the solution was/is??
04 Sep 2023 10:52 PM
Settings > Status > Network Connection > Network Setup > Advanced Settings > IP Settings > Set Manually > change DNS Server 1.1.1.1 > Confirm
04 Sep 2023 11:24 PM
What does this do ?
the lack of connection for me seems to be entirely that password disappears
- doesn't need a router reset / switch off or anything
just connect with password sorts it
But it's annoying
04 Sep 2023 11:51 PM
It solved my connectivity issue.
05 Sep 2023 12:26 AM
I am having exactly the same problem as Euan55. I have Virgin Media broadband which is working perfectly well for everything else apart from SkyQ box. The box previously had no internet issues but suddenly dropped the internet connection (wired). Tried setting up a Wi-Fi connection but this doesn't work either. What is going on here? Is Sky working on a fix?
05 Sep 2023 06:19 AM
I also have this issue now - began at something on the 4/9/23 and continued all evening. There's no issue with any other devices, only Sky Q
05 Sep 2023 06:43 AM
Mine is now working. I haven't needed to change any settings.
05 Sep 2023 07:47 AM
Same people with our skyQ and mini saying there is no internet when there is nothing wrong. Every other device is working as normal.
05 Sep 2023 07:57 AM
From 5/9/23 my skyQ box refuses to connect to my virgin media router. Says the internet is down ect . There is no fault with virgin media as all my other devices are working..
sky Q and the mini box have been working with the router for over 2 years . I'm at a loss . Can't figure out what's wrong.
05 Sep 2023 08:02 AM
Posted by a Superuser, not a Sky employee. Find out more05 Sep 2023 08:09 AM
Posted by a Superuser, not a Sky employee. Find out moreSomeone on that other thread claimed rhat changing their DNS to 1.1.1.1 fixed it which would suggest a problem with Virgin's DNS server when looking up sky services. Maybe it's happened again. Worth a try.
05 Sep 2023
08:14 AM
- last edited:
06 Sep 2023
07:39 AM
by
KevNewMedia
If you click the ? For more help, then click More Info on the settings you get this number [content removed] - I'm going to try and call this morning and see what they can do.
Moderator note: number removed
05 Sep 2023 08:14 AM
My boxes won't connect to my internet, they are connected to my broadband router but the network connection has a cross. Very frustrating trying to get support the live assistant does not help you and just takes you round in circles...my broadband works fine I work from home most days and the connection is fine. Seems both my sky q box and mini box are blocked or something.
