Discussion topic: Sky Q Mini with Virgin Hub 3 / Pod
This message was authored by: JessicaSky95
Hello all,
I have recently moved to Vrigin broadbad (cheaper, better speeds etc) however one of my Q Mini boxes is really struggling to work since doing so. I have a Wifi Pod position half way between the box & my Hub 3 router but it is not improving.
Any ways I can fix this?
TIA
Re: Sky Q Mini with Virgin Hub 3 / Pod
@JessicaSky95 wrote:
Hello all,
TIA
Hi @JessicaSky95
Afraid minis will not connect to 3rd party WiFi.
They will only connect to Sky Broadband or the main Q box.   You can also connect to an already connected mini.
Try a Network Reset on the mini found in mini Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect to nearest Q device by WPS.
You will be asked to press the WPS button on the nearest device (not on the mini you are trying to connect as the Network reset will start the WPS automatically)
Avatar for JessicaSky95
Seem to have made progress on this, moved pod next to the Q mini and plugged an Ethernet cable directly in. Now showing as connected to the pod in app and running stable.
This message was authored by: Sharon208
Both of my sky Q mini pods has blue screen and saying let's try  that again press house to refresh your connection
@Sharon208 Have you tried rebooting your main Q box ie
then
reboot your mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
