This discussion topic has been answered Discussion topic: Sky Q Mini not connecting to new Virgin Media fibre
Message posted on 08 May 2024 09:43 PM
I have Sky Q and a sky mini. Just had VM broadband installed but now mini is now connecting. VM works on the main SKY Q. Tried connecting the new network on teh mini and getting the WPS via the main box, but still no luck. States no connectivity and can't locate an IP address.
Message posted on 08 May 2024 10:22 PM
@SB55 wrote:
Hi. Yes I did.
I know you have rebooted and reset @SB55
But try the following procedure.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band which I'm sure you are aware.
When the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is try another Network reset on the mini.try a Network Reset on the mini.
Message posted on 08 May 2024 09:44 PM
Re: Sky Q Mini not connecting to new Virgin Media fibre
* mini is NOT connecting
Message posted on 08 May 2024 09:59 PM
Did you previously have Sky Broadband @SB55 ?
Message posted on 08 May 2024 10:04 PM
Hi. Yes I did.
@SB55 wrote:
Hi. Yes I did.
Message posted on 09 May 2024 09:05 AM
@oldfella thanks! Euston, we have lift off! Many thanks for your support.
Message posted on 09 May 2024 09:06 AM
Houston even haha
Message posted on 17 Aug 2024 07:18 PM
Thank you so much @oldfella , you just saved my sanity. I was having the same problem with VM broadband and q mini box, followed your instructions, and it worked. Thank you 😊
Message posted on 30 Oct 2024 11:32 AM
Jumping in here as you can answer my question. I am moving to a new house and only virgin fibre is available, hence I will have Virgin fibre but Sky Q and four mini boxes.
Can you please confirm for me that the mini boxes still get full functionality for apps, Netflix etc?
Would really appreciate an answer to this
Message posted on 30 Oct 2024 11:44 AM
Message posted on 30 Oct 2024 11:48 AM - last edited: 30 Oct 2024 11:48 AM
@Kevin1698 wrote:Jumping in here as you can answer my question. I am moving to a new house and only virgin fibre is available, hence I will have Virgin fibre but Sky Q and four mini boxes.
Yes, of course. Those streaming apps on a sky box will work on any internet connection (with enough bandwidth).
Message posted on 30 Oct 2024 12:02 PM
Brilliant thank you, another forum post suggested that the mesh network gave the minis access to the main box and recorded content, but not streaming content.
It makes sense if the main box is connected to the internet that the minis still get internet access but just wanted to double check before committing to an 18 month contract!
Message posted on 30 Oct 2024 12:28 PM
I think they use the Q mesh as a bridge to get to the internet streaming services. One of the boxes in the mesh behaves like a hub for all the others (don't think it has to be the Q itself, seems to be dynamically decided)
