08 May 2024 09:43 PM
I have Sky Q and a sky mini. Just had VM broadband installed but now mini is now connecting. VM works on the main SKY Q. Tried connecting the new network on teh mini and getting the WPS via the main box, but still no luck. States no connectivity and can't locate an IP address.
08 May 2024 10:22 PM
@SB55 wrote:
Hi. Yes I did.
I know you have rebooted and reset @SB55
But try the following procedure.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band which I'm sure you are aware.
When the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is try another Network reset on the mini.try a Network Reset on the mini.
08 May 2024 09:44 PM
* mini is NOT connecting
08 May 2024 09:59 PM
Did you previously have Sky Broadband @SB55 ?
08 May 2024 10:04 PM
Hi. Yes I did.
@SB55 wrote:
Hi. Yes I did.
09 May 2024 09:05 AM
@oldfella thanks! Euston, we have lift off! Many thanks for your support.
09 May 2024 09:06 AM
Houston even haha
17 Aug 2024 07:18 PM
Thank you so much @oldfella , you just saved my sanity. I was having the same problem with VM broadband and q mini box, followed your instructions, and it worked. Thank you 😊
