12
This discussion topic has been answered Discussion topic: Sky Q Mini not connecting to new Virgin Media fibre
This message was authored by: SB55
I have Sky Q and a sky mini. Just had VM broadband installed but now mini is now connecting.  VM works on the main SKY Q.  Tried connecting the new network on teh mini and getting the WPS via the main box, but still no luck. States no connectivity and can't locate an IP address.
Re: Sky Q Mini not connecting to new Virgin Media fibre
@SB55 wrote:
Hi. Yes I did.
I know you have rebooted and reset @SB55
But try the following procedure.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On  3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band which I'm sure you are aware.
When the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini  box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is try another Network reset on the mini.try a Network Reset on the mini.
Avatar for SB55
* mini is NOT connecting
Did you previously have Sky Broadband @SB55 ?
Avatar for SB55
Hi. Yes I did.
@SB55 wrote:
Hi. Yes I did.
Avatar for SB55
@oldfella thanks! Euston, we have lift off! Many thanks for your support.
Avatar for SB55
Houston even haha
This message was authored by: Kimbomac
Thank you so much @oldfella , you just saved my sanity. I was having the same problem with VM broadband and q mini box, followed your instructions, and it worked. Thank you 😊
This message was authored by: Kevin1698
Jumping in here as you can answer my question. I am moving to a new house and only virgin fibre is available, hence I will have Virgin fibre but Sky Q and four mini boxes.
Can you please confirm for me that the mini boxes still get full functionality for apps, Netflix etc?
Would really appreciate an answer to this
@SB55 @Kimbomac @oldfella can you please review my question above thank you
Yes, of course. Those streaming apps on a sky box will work on any internet connection (with enough bandwidth).
Brilliant thank you, another forum post suggested that the mesh network gave the minis access to the main box and recorded content, but not streaming content.
It makes sense if the main box is connected to the internet that the minis still get internet access but just wanted to double check before committing to an 18 month contract!
I think they use the Q mesh as a bridge to get to the internet streaming services. One of the boxes in the mesh behaves like a hub for all the others (don't think it has to be the Q itself, seems to be dynamically decided)
Answered - Go to Answer
