5
This discussion topic has been answered Discussion topic: Sky Q Favourites
This message was authored by: joaniesman
Sky Q Favourites
Can I change the order in which channels are listed in Favourites on my Sky Q, and if so how do I do it please?
This arises because BBC1HD has disappeared and been replaced by the relevant regional BBC1 which is now in HD.  Consequently I had to add my regional BBC1 HD to my favourites but all new additions appear in the list at the bottom whereas I want it at the top.
Re: Sky Q Favourites
Yes you can @joaniesman
See help here
After selecting Save list
you can select any content and move it..
Select Save and finish when you are done.
See help here
Avatar for joaniesman
Level 4 icon
Hi @oldfella
Thank you, again, for your help but my problem is I just can't make this work.  You say "After selecting Save list you can select any content and move it."  Sorry but I can't do that.  When I press save I get a list with a missing slot at the top where BBC1HD used to be,  It is labeled "Select to add channel".  When I select I just get the ordered list of channels with my regional BBC1 HD channel at number 1.  And I can't get anywhere from that.
@joaniesman wrote:
Hi @oldfella
Please watch the middle section of the video that @oldfella has posted as it shows you how to select & move channels up & down
Level 4 icon
@nigea99
@oldfella
Thank you both, I did get there in the end.
@joaniesman wrote:
@nigea99
@oldfella
All's well that ends well @joaniesman
