This discussion topic has been answered Discussion topic: Sky Q Favourites
Message posted on 06 Mar 2023 06:37 PM
Can I change the order in which channels are listed in Favourites on my Sky Q, and if so how do I do it please?
This arises because BBC1HD has disappeared and been replaced by the relevant regional BBC1 which is now in HD. Consequently I had to add my regional BBC1 HD to my favourites but all new additions appear in the list at the bottom whereas I want it at the top.
Message posted on 06 Mar 2023 06:41 PM - last edited: 06 Mar 2023 06:49 PM
Yes you can @joaniesman
After selecting Save list
you can select any content and move it..
Select Save and finish when you are done.
Message posted on 06 Mar 2023 07:12 PM
Re: Sky Q Favourites
Hi @oldfella
Thank you, again, for your help but my problem is I just can't make this work. You say "After selecting Save list you can select any content and move it." Sorry but I can't do that. When I press save I get a list with a missing slot at the top where BBC1HD used to be, It is labeled "Select to add channel". When I select I just get the ordered list of channels with my regional BBC1 HD channel at number 1. And I can't get anywhere from that.
Message posted on 06 Mar 2023 07:15 PM
@joaniesman wrote:
Hi @oldfella
Please watch the middle section of the video that @oldfella has posted as it shows you how to select & move channels up & down
Message posted on 06 Mar 2023 07:35 PM
Message posted on 06 Mar 2023 07:40 PM
@joaniesman wrote:
Thank you both, I did get there in the end.
All's well that ends well @joaniesman
