Discussion topic: Sky Q Box
This message was authored by: Howard0181
Sky Q Box
I have 2 4K TVs running from my Sky and the Sky Mini Box.  I have 4K on my main TV but the other 4K TV which runs from the Sky Mini Box will only display in HD quality.
This was my set up when I moved to my new house in 2021.  I was told that you cant run 4K from a mini box.
Has anything changed so I can now get 2 4K set ups.
Main reason for asking is that I am updating the 4KTV which only runs at HD.  If I cant get 4K quality not much point upgrading the TV.
Thanks for any assistance.
Re: Sky Q Box
@Howard0181
Nothing has changed. The mini boxes are not UHD compatible and that's unlikely to change in view of the expected lifespan of Sky Q.
Avatar for Howard0181
Re: Sky Q Box
Thank you for explaining the situation.
Re: Sky Q Box
4K TV's upscale HD content - some better than others...
From a Sky perspective Q will never support 4K from mini's but if you want more than one then Stream does allow for it - assuming you have sufficient internet bandwidth.  (But Stream is a very different product to Q)
Re: Sky Q Box
Thanks.  I dont really want to move to Stream.  I have good internet which is 1gig.
I have a 12 year old Sony 4K but its working fine so I think I will only upgrade if the TV does not work or if there is another way to get 4K which I  doubt.  I guess the only way around this is  a second subscription which I think is the only way around my problem.
Re: Sky Q Box
@Howard0181
It's only one TV subscription per address.
Re: Sky Q Box
A modern television is likely to be 'better' in many ways, including outputting native UHD/HDR from on-board apps.  It's only the Mini box itself which will remain HD at best, and any current model television should upscale that to UHD extremely well.
Re: Sky Q Box
Unless you're running extremely large TV's then upscaled HD is likely to be more than sufficient...
Of course, native UHD material isn't default - the majority is HD anyway...
