Discussion topic: Connect ear pods wirelessly to sky Q box. How is this done
Message posted on 12 Nov 2024 09:18 AM
How to connect earbuds to sky Q wireless using blue tooth
Message posted on 12 Nov 2024 09:34 AM - last edited: 12 Nov 2024 11:04 AM
Re: Connect ear pods wirelessly to sky Q box. How is this done
It's not done: this isn't supported from Sky Q.
It may be possible to link wireless earphones to the television set attached to the Q box. Q itself allows Bluetooth audio input but not output.
Note the Google AI response to this query is inaccurate: it appears to be getting Q mixed up with Glass.
Message posted on 12 Nov 2024 09:38 AM
@TimmyBGood wrote:
It's not: this isn't supported from Sky Q.
Not natively.
You would have to purchase an external adaptor to do this - there are HDMI to BT extractors around but I cannot vouch for any particular model/compatibility.
Message posted on 12 Nov 2024 10:55 AM
Your duplicate post asking the same has been removed as you've already received responses on this thread.
