Discussion topic: Sky Q Box keeps disconnecting from WIFI
Message posted on 14 Oct 2024 12:19 PM
My Sky box keeps disconnecting from the WIFI ever since I upgraded the WIFI. I can't even reset it using the button on the side of the WIFI router as this process has never worked and I have to mannualy add the password which then takes at least 3 attempts to connect again.
Nothing else is affected.
Message posted on 14 Oct 2024 04:49 PM - last edited: 14 Oct 2024 04:50 PM
Re: Sky Q Box keeps disconnecting from WIFI
@Bezzer1989 who is your broadband provider ?
If its Sky which router do you have the black or white ?
Message posted on 14 Oct 2024 05:46 PM
I have the white one, I used to have a black
one but upgraded. This never happened with the black one
