903
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q Apps pixelating
Locked
This message was authored by: Meldrewman
Re: Sky Q Apps pixelating
I must say that this issue has made me look at Stream - despite initially being sceptical - but it still seems to be a work in progress and with some limitations.
There is a dedicated Community forum which, after I'd read many of the posts, gave me a good insight...
This message was authored by: Hevnden208
Bad picture quality on Netflix, Amazon & Paramount, You Tube is ok
Over the past month or so we are experiencing picture breaking up, like mosaic effect/pixel problem? On any channel that is streamed, Netflix, Amazon and Paramount, You Tube ok.
@cmoh wrote:
The engineer who came also said he thinks Q will be discontinued in the not to distant future and stream was the way to go
As discussed in other threads, if the satellite company SES doesn't choose to invest several hundred million pounds in orbital hardware to replace the Astra 28.2E cluster before the end of this decade, all satellite television broadcasting to the UK will cease.
Re: Bad picture quality on Netflix, Amazon & Paramount, You Tube is ok
@Hevnden208 I have moved your post into the large thread all about this problem have a read of the 2nd post on page 1 the post marked as the answer
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: melee79
Hi - I have several apps such as Disney and prime pixalating a lot while playing.
I have the router wired into the SkyQ box and and getting speeds of 300+. That helped for about a hour (previously via WiFi, with speeds of only 34mbps). It can get quite distracting at times.
We have a 3rd party for internet and o ly halpenes when watching through SkyQ
Any suggestions would be greatly appreciated.
Re: topic: Sky Q Apps pixelating
@melee79 I have moved your post to a larger thread all about the same problem.
Have a read of the 2nd post on page 1 the one marked as the current answer
This message was authored by: Datamitch
I've been getting the same issue on all Apps for a while, then you get an email that your price is going up by 15%. #Joke.
This message was authored by: JG215
Having the same issue. Apps are all pixilating while watching anything. Internet is working fine.
This message was authored by: MatthewR84
I have the issue too on Netflix via the Sky App with internet of 290Mbps. Doesn't seem to happen with Discovery + but haven't watch that much.
This message was authored by: Oreobiscuit
I had this problem on streaming apps Netflix, Disney, prime and paramount plus. Had a sky q box change but the problem has returned. It's slightly raining today but the affect on the picture pixelation is horrendous. I understand that heavy rain and snow on the dish can cause issues but surely light rain shouldn't be a big deal....
This message was authored by: Nynja+Squirrel
Those apps don't use your dish, they use your broadband connection.
But - I have the same issue, and it's really turning me off Sky completely, it's been months now. Same apps are fine on tablet, PC, TV, just not SkyQ box. This needs some serious attention.
This message was authored by: type-r
Out of interest, when you had your Sky Q box changed, how long were your apps working for before the problem returned?
Same issue.
No issues at all using any other device.
As we watch about 90% of our TV this way (via SkyQ) and very little actual Sky TV, only keeping it and the channels we keep re-contracting with out of habit, I think it's about time to move on now that the choices are there
This message was authored by: KinardUK
So a quick follow up from me, after replacing our Sky Q (2017) box with a new one, the problem has disappeared for us.
This message was authored by: JibbaJoy
Hi @KinardUK , can you tell me the hardware version of your new box please [mine is 32B061 probably a 2021 version]
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
Locked
Answered - Go to Answer
