Discussion topic: Sky Mini box
Message posted on 17 Mar 2024 11:38 AM
Sky Mini box
Have been a Sky customer for some time with Sky Q and multiscreen-however in the last 2 days the mini box is freezing -similar to that with the Sky dish with thunderstorms etc. Have had the mini box for some years -is it on its way out ?--No problem with the TV when connected to outside aerial-or is the simple answer to rer-set the box ?
Message posted on 17 Mar 2024 12:05 PM
Re: Sky Mini box
Hi @Daviebowls
Try resetting the Network on the mini box.
Reboot the mini as above.
Message posted on 19 Mar 2024 09:11 AM
Re: Sky Mini box
Many thanks for the info have done everything that you has suggested. However the problem is still there. I have moved the mini box to different rooms and connected to the TV's there and there is no problem receiving sky channels and playing recordings. Have reconnected the mini box back to its original position in the bedroom and played back recordings and the screen freezes but does not on live sky channels so it seems the box is receiving signals but not on recordings?
Message posted on 19 Mar 2024 09:50 AM
Re: Sky Mini box
Hi @Daviebowls
certainly shouldn't be a problem with the mini if it is OK with other room TV's.
Is it's normal location further away from the main Q box or are there more obstacles between them?
Would think it must be a WiFi issue at that location.
Message posted on 19 Mar 2024 10:30 AM
Re: Sky Mini box
The position of the Mini box amd sky Q box has not changed for some 6 years and have had this issue only in the last two weeks-it seems playing back recordings is the only issue-is it as simple as getting a wi-fi booster or is the problem lies deeper
Message posted on 19 Mar 2024 10:33 AM
Re: Sky Mini box
You will only know if you try with a booster @Daviebowls .
WiFi is unpredictable. Don't forget if you get a Booster it must be a Q WiFi booster from Sky.
