6
This discussion topic has been answered Discussion topic: Mini-box not working
This message was authored by: chris777chris
Sky had problems last night, but I still can't get the mini-box to work (says there is no connection). Main box is fine with Status showing good on everything.
This message was authored by: PandJ2020 Answer
Re: Mini-box not working
Have you tried rebooting the main box too?
Avatar for chris777chris
Level 0 icon
Yes I've tried rebooting the main box (twice)
This message was authored by: Waz1978
My sky box is not working
@Waz1978 can you give more information ie what is happening when you try and use your box are you getting any error messages on screen
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Linda888
The box has not been working for two days. I have switched it off and on a number of times and changed the batteries on the remote but still not working.
No but I will try that now!
