Discussion topic: Sky Mini box
Message posted on 13 Mar 2023 12:15 PM
Sky Mini box
Sky multiroom minibox not working. Tried rebooting and resettin but does not respond to remote. Amber light on all the time.
Message posted on 13 Mar 2023 12:19 PM
Re: Sky Mini box
Have you tried switching on the mini by pressing the standby button on the front of the box (Amber led)?
Message posted on 13 Mar 2023 12:46 PM
Re: Sky Mini box
Can you try re-pairing the remote to the Mini Box by pointing it at the box and press/hold the number 1 and 3 together for three seconds.
The remote should then flash red a couple of times.
Afterwards try pressing the Home button on your remote to see if the box comes on.
Let me know how you get on.
Tom
Message posted on 09 Jun 2023 11:26 AM
Sky Q Mini Box not working
Can anybody help with this? My SkyQ Minibox in my bedroom does not work. It shows an Amber light but that's all it does. It does not respond to the remote control {which has decent batteries}. I have tried the reboot, reset, and power off solution but no luck.
Powering off the box and resetting it just shows an amber light that briefly flickers, no green light.
There is nothing showing on the screen.
Message posted on 09 Jun 2023 11:35 AM
Re: Sky Q Mini Box not working
Has it worked at all since you first posted about this issue in March? Have you tried the advise already provided or have you called Sky to report this?
Message posted on 09 Jun 2023 01:39 PM
Yes it worked initially after the emgineer instslled it. I have tried the power off reset but no luck, I have contacted sky yet
Message posted on 09 Jun 2023 01:40 PM
Not contacted sky yet
Message posted on 09 Jun 2023 01:45 PM
Have you followed the advice from @Tom-W19 which was:-
Message posted on 10 Jun 2023 03:36 PM
Re: Sky Mini box
It worked a treat! Thanks
