Discussion topic: My Sky boxes are not connecting to internet
This message was authored by: Amits77
Sky boxes not connecting to internet
Re: My Sky boxes are not connecting to internet
Hi @Amits77
Try a Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
