Discussion topic: Sky Mini box settings say it's connected but on screen says it's not
Message posted on 14 Jun 2024 12:26 PM
Whilst watching our Sky Mini box it regularly stops working, saying it is not connected to the Sky Q box. However, in Settings it shows it's connected to both the internet and the Sky Q box. The Sky Q box settings also show it's connected to the mini box.
We recently renewed our contract with Sky and the Sky Q box was replaced to try and solve the issues but this hasn't worked.
We've tried rebooting both boxes but this doesn't make any difference as they maintain connection all the time. The mini box also gets hot - not sure if that's the issue.
Message posted on 14 Jun 2024 12:51 PM
Re: Sky Mini box settings say it's connected but on screen says it's not
Hi @VJ5
Minis do get quite warm but not so hot that you cannot easily hold your hand on them.
You could try completely resetting the Mini connection.
Reboot the mini as above.
