Discussion topic: I am getting picture distortion and sound loss when I view reoordered programs
Message posted on 14 Jun 2024 12:45 PM
When watching recorded programs on Sky Q box I am getting picture freezing or breaking up at random and sometimes loss of sound
Message posted on 14 Jun 2024 12:52 PM
Re: I am getting picture distortion and sound loss when I view reoordered programs
Hi @Haresh225
