Discussion topic: Sky Mini Box
Message posted on 18 Jun 2025 09:37 AM
Sky Mini Box
Message posted on 18 Jun 2025 10:34 AM
Re: Sky Mini Box
Is this happening before 0545 in the morning?
Message posted on 18 Jun 2025 10:41 AM
Re: Sky Mini Box
Well its every evening, around 10-1030pm
Message posted on 18 Jun 2025 10:43 AM
Re: Sky Mini Box
Perhaps reboot your broadband then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 18 Jun 2025 11:07 AM
Re: Sky Mini Box
We do this every night 😓 i go downstairs unplug thr router and main box for 15 minutes plug it back in reboot it all do the same upstairs reconnect it all and it works,sometimes for about half hour sometimes it stays on. But its every night we have to do it and its getting a bit annoying
Message posted on 18 Jun 2025 12:53 PM
Re: Sky Mini Box
@Jade0890 wrote:
So I've had sky since January. We've got the sky Q box dow stairs, and a mini box upstairs. Every night for the last few weeks weve turned the mini box on, and its saying either unable to connect to network, or unable to connect to sky Q box. We are having to reset the box and connect it back to the main box downstairs. We've not had any issues with the main box, its just the mini box. Sky can you help???
When you say "turned the mini box on" do you mean 'bring it out of standby' via the remote control, or 'turn it back on at the mains'?
Message posted on 18 Jun 2025 01:32 PM
Re: Sky Mini Box
Sorry i should have said that! Turn it on by the remote control
