Discussion topic: Sky Mini Box
This message was authored by: Jade0890
Sky Mini Box
So I've had sky since January. We've got the sky Q box dow stairs, and a mini box upstairs. Every night for the last few weeks weve turned the mini box on, and its saying either unable to connect to network, or unable to connect to sky Q box. We are having to reset the box and connect it back to the main box downstairs. We've not had any issues with the main box, its just the mini box. Sky can you help???
Re: Sky Mini Box
@Jade0890
Is this happening before 0545 in the morning?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Jade0890
Re: Sky Mini Box
Well its every evening, around 10-1030pm
Re: Sky Mini Box
@Jade0890
Perhaps reboot your broadband then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for Jade0890
Re: Sky Mini Box
We do this every night 😓 i go downstairs unplug thr router and main box for 15 minutes plug it back in reboot it all do the same upstairs reconnect it all and it works,sometimes for about half hour sometimes it stays on. But its every night we have to do it and its getting a bit annoying
This message was authored by: Invisiblename
Re: Sky Mini Box
When you say "turned the mini box on" do you mean 'bring it out of standby' via the remote control, or 'turn it back on at the mains'?
I am just another Sky customer!
Avatar for Jade0890
Re: Sky Mini Box
Sorry i should have said that! Turn it on by the remote control
