2
This discussion topic has been answered Discussion topic: Sound dropping out
This message was authored by: Westy643
Sound dropping out
I've just had my Q box replaced and I'm now getting sound drop outs on live tv not recordings. If I switch the power off to the Q box and it reboots then the drop out issue resolves itself. Anyone have any ideas??
My Q box is hdmi connected to the Sky sound box and then hdmi connected to my Samsung tv
Avatar for Westy643
This message was authored by: Westy643 Answer
Re: Sound dropping out
Thanks for your reply, I was all set to follow your instructions on Sunday morning, I turned the tv on as normal and the sound issue had resolved itself, it's been perfect ever since.
Hi @Westy643
Try a Reset Settings in the Q box hidden menu.  See if this is more permanent
Avatar for Westy643
