Discussion topic: Sky Max chanel unwatchable
This message was authored by TB126 This message was authored by: TB126
Trying to watch Sky Max tonight (23/12/24) but it is unwatchable as it's jittery with sound and picture freezing, tried other chanels and they seem ok.
This message was authored by Chodley This message was authored by: Chodley
Re: Sky Max chanel unwatchable
Sounds like weather / tree issues.
@TB126
If that was a transmission issue we'd expect multiple posts in this forum, so as @Chodley indicates it does suggest an individual reception problem.
TB126
Thank you for your reply.
No other channels were affected though and I did check the signal strength and there were no issues reported.
This message was authored by PandJ2020 This message was authored by: PandJ2020
The signal strength is a guide - it is only one particular transponder.
A slight dish misalignment could affect one (or more) channels.  Movies seems particularly sensitive to misalignment.
I am just another Sky customer and my views are my own
This message was authored by JVC999 This message was authored by: JVC999
I am having the same issue, all other channels are fine ,just sky max which is un watchable
