Discussion topic: Sky Max chanel unwatchable
This message was authored by TB126 This message was authored by: TB126
Trying to watch Sky Max tonight (23/12/24) but it is unwatchable as it's jittery with sound and picture freezing, tried other chanels and they seem ok.
This message was authored by Chodley This message was authored by: Chodley
Re: Sky Max chanel unwatchable
Sounds like weather / tree issues.
@TB126
If that was a transmission issue we'd expect multiple posts in this forum, so as @Chodley indicates it does suggest an individual reception problem.
TB126
Thank you for your reply.
No other channels were affected though and I did check the signal strength and there were no issues reported.
This message was authored by PandJ2020 This message was authored by: PandJ2020
The signal strength is a guide - it is only one particular transponder.
A slight dish misalignment could affect one (or more) channels.  Movies seems particularly sensitive to misalignment.
I am just another Sky customer and my views are my own
This message was authored by JVC999 This message was authored by: JVC999
I am having the same issue, all other channels are fine ,just sky max which is un watchable
This message was authored by xenon81 This message was authored by: xenon81
When you have trouble with Sky Max, is Sky Witness also affected?
Hi, no sky witness is fine
Thanks for your reply
This message was authored by Aemac This message was authored by: Aemac
Exactly the same here. Sky Max unwatchable but everything else is fine
Just to confirm are those affected in the UK or Ireland, and are you watching HD or SD?
TB126
In Uk on SD.
Sky witness is fine, just tried Sky Max and still a problem.
This message was authored by Boscar This message was authored by: Boscar
Mine is the same on sky q and the mini box. WiFi all good, signal strength good, all other channels are fine, but this is unwatchable!
Having checked the UK SD version i'm seeing the same occasional picture stutter/break up. Other channels on the same transponder are fine, the HD version seems OK too, so it seems to be an issue at Sky's end.
This message was authored by Failedfosterer2 This message was authored by: Failedfosterer2
Same issues here for last few days.
So annoying. No weather issues/trees etc. So presuming it's an issue at sky's end.
So annoying.
This message was authored by pablo... This message was authored by: pablo...
Same issue here. Programmes (and ads) stutter, repeat and occasionally lose audio. Not easy to watch.
