2
This discussion topic has been answered Discussion topic: Amazon prime sound issues
This message was authored by: PB22
Hi having issues with sound on Amazon prime, as soon as I join the show sound is ok then drops out after a few seconds and never recovers. This is running on a Sky q mini box with a WiFi booster. On the main SkyQ box also watching Amazon prime without issue. If I leave Prime the mini box then shows a technical fault and needs to be restarted. Checking the connections on the mini box both wifi and skyq show as connected. We have sky fibre internet.
Re: Amazon prime sound issues
Hi @PB22
Try resetting the mini connection.
Reboot the mini as above.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Sky Q WiFi booster.
You will be asked to press the WPS button on the booster (not the mini as the Network reset will start the mini WPS automatically).
Hi @PB22
Avatar for PB22
Worked a treat, thanks!
