Discussion topic: Sky Essentials Channel Missing
This message was authored by: Melissa31d
Hi! I was wondering if anyone could help - it says that I have not subscribed to Sky Atlantic even though it says that it is included in Sky Essentials (it was also mentioned when I spoke to advisors when changing my TV package) - what do I do?
Re: Sky Essentials Channel Missing
@Melissa31d  Sky Atlantic via essentials is only available on glass/stream not Q
 whilst similar named between the two platforms the channel choice within the two different packages are different
Indeed - if the advisors said you will get Atlantic on Q essentials then they have misled you...
hi @Melissa31d
As the others have indicated, SKY rather unwisely have used very similar names for slightly different products on different platforms.
SKY Essentials on SKY Q  is just the Free To Air channels and does not include SKY Atlantic or Netflix, whereas the similarly named Essential TV streaming package (on SKY Glass/Stream) does include SKY Atlantic & Netflix
As mentioned, by @PandJ2020  if SKY advisers told you otherwise they are wrong & may have misled you.
@Melissa31d
Unfortunately multiple online sources (including AI search results) get 'Sky Television Essentials' on Sky Q confused with 'Sky Essential TV' in Glass & Stream.
Avatar for Melissa31d
Thank you everyone for your support! Is it possible to source the transcript of online chats?
If it was a chat it may reappear if opened again.
Otherwise submit an access request.
