Discussion topic: Sky Documentaries
This message was authored by: Sjulian
Sky Documentaries
The sound on live and recorded programmes does not sync with picture on Documentaries channel. It seems ok on all other Sky channels. I have tried all the workarounds suggested on the App. Is this a general issue? What's the solution? I have Sky Q.
Re: Sky Documentaries
@Sjulian
Does that include a box reboot?
Its always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: Maniatore2006
I had the same the last days.. is is a channel problem or was i will check it later again.
Update: it is still a problem.
SKY Q, With Entertainment SD and Sky Sports HD.
Update 11.07
The Channel is Fine Again.
And now Comedy Central SD Has this Problem...!
