24 Dec 2024 07:43 PM
Is anyone having daily problems with their Sky Q main box and mini boxes. They appear to be losing connectivity to the internet , not being able to connect and get a signal from the main box or have no connection to the Sky Activation server. I am trying to find out if this is just my issue or Sky have a chronic issue across their customer base
24 Dec 2024 07:56 PM
Hi @JOHNDP13
Try completly resetting your connection.First reset your broadband router.
Once you get the main Q box connected
try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
24 Dec 2024 08:53 PM
Yes! We keep losing connection to our boxes, seemingly at random. Some days it is stable, while on others it drops out frequently. It's very frustrating. We have fibre internet at 1000mb/s (symmetrically) and all other internet-connecting devices are trouble-free.
24 Dec 2024 08:59 PM
Thanks for responding. I also have 1000 mb internet so that's not the problem but the notification frequently says lost internet connection. As you say it happen anytime. Same with losing mini box connectivity to the main box. I am the end of my tether after having Sky continuously for about 25 + years. It's become a total nightmare and feel I spend half my time resetting the boxes, powering them off and on. I just don't think the platform is stable any more
24 Dec 2024 09:16 PM - last edited: 24 Dec 2024 09:27 PM
Q is in use in millions of households: two posts with not entirely similar symptoms don't really indicate a systemic issue.
A lot of individual Q hardware is however now rather old.
24 Dec 2024 10:29 PM
We are having the same issues......no signal issues, no BB issues however box is freezing/glitching, also advising technical fault on this channel and also recordings.
Have did reset, switched from wired to WiFi connection and back again but issue persists. Trying to manage it due to festive period but will need to get an engineer out as soon as I can I reckon 😞
25 Dec 2024 08:08 AM - last edited: 25 Dec 2024 08:08 AM
@Sooty78 wrote:We are having the same issues......no signal issues, no BB issues however box is freezing/glitching, also advising technical fault on this channel and also recordings.
Sounds like the box just needs replacing. That can be done via courier.
25 Dec 2024 08:11 AM
@JOHNDP13 wrote:Thanks for responding. I also have 1000 mb internet so that's not the problem but the notification frequently says lost internet connection. As you say it happen anytime. Same with losing mini box connectivity to the main box. I am the end of my tether after having Sky continuously for about 25 + years. It's become a total nightmare and feel I spend half my time resetting the boxes, powering them off and on. I just don't think the platform is stable any more
The connection problem is the wifi between the boxes and the router, not the internet connection. I would just get powerlines (cheapest but more prone to issues) or hard wire each box into a wifi mesh and in either case disable wifi on the sky boxes.
25 Dec 2024 10:16 AM
Thanks for your suggestion. Box has been changed already
25 Dec 2024 10:43 AM
Having all the same issues!!
