Discussion topic: Sky Documentaries
Message posted on 07 Jul 2026 10:35 AM
Sky Documentaries
Message posted on 07 Jul 2026 10:43 AM
Re: Sky Documentaries
@Sjulian wrote:
I have tried all the workarounds suggested on the App.
Does that include a box reboot?
Its always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 07 Jul 2026 11:33 AM - last edited: 07 Jul 2026 11:35 AM
I had the same the last days.. is is a channel problem or was i will check it later again.
Update: it is still a problem.
Message posted on 11 Jul 2026 09:41 AM
Update 11.07
The Channel is Fine Again.
Message posted on 12 Jul 2026 11:06 PM
And now Comedy Central SD Has this Problem...!
