9
This discussion topic has been answered Discussion topic: Sky Dish
This message was authored by: Kazzy62
Sky Dish
My sky dish is over 20 years old and the signal is terrible in any slight weather change. Can I get a new one without having to pay ?
Re: Sky Dish
@Kazzy62 wrote:
I just wanted to speak to someone and explain the problem. It only has to rain slightly and I lose signal. It's got worse over the years I know lots people with sky q and don't have these issues something is just not right and can't find a number or contact message to speak to someone I don't want a digital answer I've tried all that. It just frustrating there is no help. Thanks for your reply though.
Hi @Kazzy62
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Re: Sky Dish
@Kazzy62
Do you have Sky+ or Sky Q?
Avatar for Kazzy62
Re: Sky Dish
We have SkyQ
Re: Sky Dish
@Kazzy62
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Kazzy62
Re: Sky Dish
Might sound  silly but how do you actually contact sky to make an appointment for an engineer as it's not exactly jumping out at me on there app
Re: Sky Dish
hi @Kazzy62
Check through the link posted by @Daniel0210
and you will see the following
Check the signal strength
If your satellite signal has returned, test a few channels to make sure everything's working as expected. If there are any problems, or if you still don't have a satellite signal, you'll see a link to book an Engineer visit online
Re: Sky Dish
Avatar for Kazzy62
Re: Sky Dish
Re: Sky Dish
Hi @Kazzy62
To contact Sky
Re: Sky Dish
Dish is probably slightly misaligned
