Discussion topic: Frustrated
Message posted on 20 Sep 2025 09:10 PM
Frustrated
Every Day this week, I've had issues with ny Sky Q and it's been off today for 6 hours Done all the usual switch off, checked cables 😡 Thr box is about 2 months old? Any suggestions?
Message posted on 20 Sep 2025 09:39 PM
Re: Frustrated
Hi @Rachie+C
Message posted on 20 Sep 2025 10:01 PM - last edited: 20 Sep 2025 10:02 PM
Re: Frustrated
What sort of issues?
What do you mean by "it's been off..." for 6 hours?
Message posted on 20 Sep 2025 10:08 PM
Re: Frustrated
Hi yes can't watch anything? During th week it was only certain channels?
Message posted on 20 Sep 2025 10:09 PM
Re: Frustrated
And what actually happens when you try?
