Discussion topic: Mini box not connecting after renewing my deal
This message was authored by: Paul735
Minibox not connecting  after renewing my deal says I havent got the required subscription (I have) . Done everything spent 2 hrs on the phone been moved from one department to the next running through the same rigmarole which I had already done myself . Also I  had to deal with one particularly rude lady in the process . Is sky worth the hassle . Anyone had this problem resolved?
Re: Mini box not connecting after renewing my deal
Hi @Paul735
Have you checked that your package still contains the Monthly Sky Multiscreen package.
You can check this in your Q box in the Home menu under My Sky
Avatar for Paul735
Yes checked on my sky app and emails I have  received also on skys system
Hi @Paul735
  • First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
    Reboot the mini as above.
    If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the Main Q box.
Avatar for Paul735
Hi
done all of the above and more several times . The only thing i havent done is decked the q box. Which is working perfectly . I suspect that  multiscreen needs re initialising at skys end .pretty fed up with it tbh.
"Decked"?
Avatar for Paul735
Cleared.taken back to factory settings
