Discussion topic: Sky Atlantic
Message posted on 14 Dec 2025 12:36 PM
Sky Atlantic
Message posted on 14 Dec 2025 12:44 PM
Re: Sky Atlantic
Do you have HD pack? (If not you can only watch/download in SD)
Message posted on 17 Dec 2025 12:23 PM
Re: Sky Atlantic
Message posted on 17 Dec 2025 12:25 PM
Re: Sky Atlantic
Message posted on 17 Dec 2025 12:26 PM
Re: Sky Atlantic
Message posted on 17 Dec 2025 12:32 PM
Re: Sky Atlantic
@AndyE14 wrote:
Is there a sky Atlantic sd catch up channel. Who wants to watch a series starting at episode 7
Hi @AndyE14
On the Download in question you need to look for the All formats option under the tile. This will give you all the available resolutions available for download.
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
