This discussion topic has been answered Discussion topic: Mini box not working
Message posted on 17 Dec 2025 12:03 PM
Mini box not working at all
Message posted on 17 Dec 2025 12:27 PM
Hi @IainDuncan
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @IainDuncan
