Discussion topic: Sky Apps
Message posted on 18 Jan 2026 04:40 PM
Sky Apps
Message posted on 18 Jan 2026 06:23 PM
Re: Sky Apps
Sounds like the main Q doesn't have a great wifi connection
if you go into the netflix app/get help/network test, what speed does it report?
Message posted on 18 Jan 2026 06:37 PM
Re: Sky Apps
The connection says 48.69mbps but we have a 1gb service so that is shocking!
Message posted on 19 Jan 2026 07:18 AM - last edited: 19 Jan 2026 07:19 AM
Re: Sky Apps
@ebonitestorm wrote:The connection says 48.69mbps but we have a 1gb service so that is shocking!
You will never get close to 1Gb on the Q's 2.4GHz wifi.
UHD needs about 25Mb so that's actually ok. I get 89 on a 1Gb connection.
Box might have a hard drive that's failing.
Message posted on 19 Jan 2026 08:02 AM
Re: Sky Apps
It is a brand new box as they thought it may have been the box previously!
It is just so frustrating when you are watching one of the apps and it either stops and switches off or it does like the old style buffering every couple of mins. It doesn't happen on any of the mini boxes at all.
Message posted on 19 Jan 2026 08:05 AM
Re: Sky Apps
Are the minis closer to the router?
Message posted on 19 Jan 2026 08:36 AM
Re: Sky Apps
No further away. We have hard wired the SkyQ box. Will see how it goes
Message posted on 19 Jan 2026 08:03 PM
Re: Sky Apps
Hope it remembers to use ethernet. Has a habit of changing its mind if you leave wifi enabled for the minis.
