Discussion topic: Signal to Q box dropping out every 10 mins.
Message posted on 13 Dec 2025 10:29 PM
Moved home into an apartment block. Sky signal through a comms room and other 7 occupiers have no issues.
after considerable difficulty fully installed my Qbox and achieved connection to network. However I have been experiencing signal drop out approximately every 10 minutes with a blank screen for up to 1 second.
I have switched everything off.
I have checked all cable connections.
I have connected to my new full fibre hub.
internet signal good and feeding other devices.
can it be my QBox which I brought with me is faulty or needs update.
This fault is beyond me.
Surely I need an engineer visit. I am 75 and struggling with IT.
Message posted on 14 Dec 2025 12:02 PM
Re: Signal to Q box dropping out every 10 mins.
@MRB+Lisburn it sounds you are on a communual systems if so have you gone in to the engineers menu and changed the lnb setting from wideband to scr
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
